I have just received back my dash from Ferdi who has installed his integral gear indicator into it, he also sent an Italian version of the set-up procedure which I translated into english through google translate. Unfortunately even with it translated I am still unsure of the exact procedure.
Can someone who has had this installed put together and post a straight forward procedure for this.
Regards Glenn
Press the set button withing 10secs of starting the engine, ride through all the gears when asked (<3500 rpm), after the last gear is set, pull over and wait for the 'P' to be displayed.....simples
see attached
Adam
I've been looking at this mod as I'm fed up trying to find 7th, after coming from a Vtwin the engine seems to be rev'ing its nuts off
how much did it cost for the clocks to be moded and how did it take to get them back to UK
cheers
Cost to modify was €310 and return postage was €40 and it took a total of 1 month from sending it to receiving it back. Glenn
