1 - 6 of 6 Posts
I couldn't easily get my hands on a factory GPS and mount from MV so I went the aftermarket route. First I bought the Garmin 595 LM, which was cheap when purchased with points from my Amex card. It comes with a mounting bracket and a Ram mount but I wanted the custom look. For the handlebar mount I used this: S-R1 Universal Ultra Compact Metric Triple Clamp GPS Mount from Motorcycle GPS & Device Mounts for BMW, Ducati, Honda, Yamaha Suzuki - mounting solutions for electronic devices | MotoGPS | Clamp mounts, GPS mounts, RAM mounts | motogps.com.au | Australia
The mount is spectacular and I was shocked when I ordered it online from Australia last Sunday and it was delivered here in Houston on Friday. It matches the aluminum mounts for the handlebars and comes with several mounting bolts and spacers to allow you to set the screen in any angle or height you want. My setup allows the GPS to be comfortably underneath the view of the dashboard screen. Once tightened down its solid as a rock but note it has built in rubber spacers for the Garmin mounting bracket which act as a shock or vibration absorber.
Once all tightened down I added my radar detector, a Valetine one with front, rear and side protection. For that I used a Quad Lock Out Front mounting bracket and a stick on adapter which goes on the detector. Take a look at the finished cockpit, I think it came out rather well.
Take care guys.
That mount looks beautifully engineered and a secure way to mount your GPS. The 590/595 Zumos are pretty large and fitting them into the Turismo cockpit is difficult without obscuring something.
I have a 590 but use a tank bag so I'm not sure if the mount you've used would work. I went for a RAM mount in the end, have used this system on previous bikes and it works well.
above taken before I got the 590, I already had the RAM parts so was an easy no cost option
My tank bag is a small Givi one though I've just ordered a bigger one from the same Givi Tanklock range as I have a series of three European trips planed for this year. I hope that my current mount will work without fouling this.
How are you getting on with the 595? I used to run a 660, with several other m/c Garmins before, and find that it works in a different way. It has a few foibles by comparison. It still works well but these issues can make using it a bit frustrating at times.
Hi Markammerman,
I do have the MV mount for my Zumo 340, but before, I used a Ram Ball fixed on the same bolt than the one used in first picture. The advantage of those is you can use different length of arm to mount the GPS, making it easy to find the right position.
With your mount, I suspect you can't use a tank bag (both for visibility and positioning the tank bag)... But that is also question of personal use, and looking at what is fitted on your left panier, I guess they are both fitted all the time...
The S-R1 mount shown on their web page seems just like the original OEM solution, maybe you could also use it at the position on the screen instead on the handelbar. Have you tried this solution? I also wonder what is the price for the OEM solution and what is the part number to order if anyone knows?
Can you adjust the screen with this, with the GPS mounted, in place? Having looked at one of these mounts in a showroom I was put off by that aspect.
Well, I can adjust the screen with the GPS mounted in place. It's even possible while riding, but it is difficult, cumbersome, and I'm actually stopping to do it. But I do not actually move the screen very often : i like the wind to remind me a bit of the speed, and actually use the upper position only when on highway, and I simply change the position of the screen before and after.
And I prefer the position of the GPS where it is now. And the ball mount is still there on the handlebar, ready to receive the phone, just in case (it may be overkill, but I remember the lead rider of a group having his GPS constantly rebooting and no way to guide us anymore at some point - we fixed the issue during lunch, thanks to someone having a laptop, a Usb cable, being able to extract the gpx from his GPS memory and put it on another one - since I have the GPS, I keep the phone with an application able to do the job with me, just in case).
1 - 6 of 6 Posts
