1 - 19 of 19 Posts
I was out on a ride today and the bike sputtered to a stop. The fuel pump runs when the key is on and builds pressure and stops. Then when I hit the starter the bike runs for about 2-3 seconds and then dies. If I turn on the key and lit the pump run and build up pressure and then hit the key again or the kill switch the pump will run again. When I got home via friends truck and the help of Carl and Jeff pushing it on. Pulled the tank and pump and all the hoses looked fresh.
Any Ideas and has anyone had to replace a fuel pump. Can the symptom be from a clogged fuel filter? I don`t want to start yanking fittings with out any thoughts first.
Chris.:cry:
Wow, that was fast!
I still wonder if it not some sort of electrical gremlin. If you put my pump in the the problem still exists you can rule out the fuel pump as the problem.
Isn't there a relay that turns the fuel pump on and off with the starter button? Seems like I remember someone having a problem with it. Sorry not much I help, but could be something to checkout.
i think the relay is built in the fuse box that was replaced. And unless the pump shuts off once the bike starts ( which is posable ) I don`t think that is the problem.
The fuel pump was replaced on my 2004 Brutale S at around 7k miles to correct a stalling condition. I wasn't the owner of the bike at the time, just got the information from the local dealer that performed the work when I requested the bikes history. I believe the cost for replacement was ~$450 for parts and labor.
Are you sure its the pump not working and not the fuel cap blocked and not letting any air in
I was there with Chris when the bike died. It happened just as the reserve fuel light came on so at first he thought he was out of fuel. He filled up but still could not start the bike.
If you prime the fuel system more than once either by twisting the key on and off or hitting the kill switch several times, it will run longer than if you just let the pump prime once, but it still dies. Cracking the throttle kills it quicker than if it just idles.
Tried it gas cap open, closed. As he posted, no lines look kinked or collapsed.
It sounds like it is not pushing enough fuel to keep the system pressurized.
The whine from the pump when it was priming was also louder than my SPR or Jeff's 910R.
Very strange.
I`m going to pull the fuel filter this morning and see if it is restricted and post my findings.
OK the fuel filter was slightly restricted but still had flow. I ran some compressed air through it in both directions and it has no restriction at all now. I guess I can reinstall it and see if that did the trick. If so than it`s a cheep fix for a new filter.
:brutale::f4::drummer:Holy Shit!!!!!holy Shit!!!!! That Did The Trick!!!!!!!
Time For A New Fuel Filter!!!!!!!!:highclap::highclap::highclap:
Discussion Starter #17
Do you get your gas from the same garage?
The bike has over 11K miles.
Perhaps it`s on the list of service intervals.
I will have to look.
Besides it`s a B750 SO IT DOES NOT PASS TO MANY GAS STATIONS WITHOUT NEEDING A GULP. Every 100 miles so it has had over 110 fill ups.:moped:
1 - 19 of 19 Posts
