I need advice from those of you knowing a little about the newer Brutales. I have a fuel pump (one outlet not quick fit) and tank assembly from a (I think) 2010 Brute, will the pump fit my 2004 Brute? If not what mods are required to make it fit? I bought it unseen just to have a spare.
too much work to make it fit.......
your '04 has the pressure regulator on the return line.....i guess you could wye the lines together
but you would lose the advantage of more even temperature of the fuel in the old style system
sell it:drummer:
fuel systems that dead head against the injector (BMW R bikes for example) have fueling maladies related to cylinder temp and the sun on black lines
stick with your stock system....
if you need a new pump.....just buy the pump only off ebay:drummer:
