1 - 6 of 6 Posts
Hi all,
Just had my tank off on the 750s to change the Eprom. All went fine but I just want to check something....
I read the fuel connectors were colour coded so stupidly didn't take note of which went to black and which to yellow. The only thing I could see to indicate any coding was 2 dots on one of the connectors, these ate black so I connected them to the black fitting.
All correct? She seems to run fine but I wanted to check before getting stuck miles from home.
Hi all,
It makes no difference which way around you connect
joe
You should be more worried about the plastic fittings breaking and think about replacing them with metal fittings. Look in the Maintenance section, this is not just a Brutale issue but also a F4 one.
Both.
I have replaced the "L" connector on the pipe, but soon I broke the connector on the tank side, so it is better to replace both at once.
1 - 6 of 6 Posts
