1 - 13 of 13 Posts
I need to get new fuel lines that go to the fuel filter so what type of line is needed. It has to be something that will withstand being in the fuel tank
Are you taking the Mickey out of us George ? Hahahha, surely you are as you've been a round here so long that you couldn't possibly have missed the Tech Tip section OR this thread http://www.mvagusta.net/forum/showthread.php?t=39000
Type of hose is on the 1st page, Chuck might have some he'd flogg you, but it's available everywhere in your neighbourhood.
No offence to anyone intended, but does anyone read emails, posts etc. properly? It's all so pervasive now it's like having a pub conversation with heaps of noise around. Nobody pays attention. Must be getting old. Makes me feel it anyway.
Deano
George, I do have what you seek.
I could probably have done a search and found what I needed but then I wouldn't have received the verbal abuse. So much more fun this way :)
Hahaha, you old sook, nobody abused you although I thought about it when you posted this in the Performance section :):thewife:
You've been on this Forum for so long that you should be telling others where to find stuff :yo:, anyway, you have my number and email, you know you can ask anything - anytime, and contrary to what some USA members think, we can be reached from anywhere in the world:ahhh: even if it's just a text(Sms).
Take your time, you have other bikes to ride if this projects not finished, not worth messing it up in a hurry.:yo:
George:
What you need is 12" of 5/16" SAE J30R10 hose...... submersible FI hose
Goodyear, Dayton and Dayco make it
the filter is a WIX #33012
go to page K02 oc the F4 parts manual
remove the canister
remove #4, put #5 where #4 was
wye #5 & #6 to #7
epoxy the 2 fuel pump plate through fittings on the inside of the plate
with the same batch of epoxy fill and smooth the 3 notches next to the gas cap studs
a 31 page thread reduced to 6 lines
:popcorn:
Noel thanks. I only needed some fuel line for the fuel filter connections. I have removed the canister and Y'd the lines
George;
the Clic-R clamps that go on the filter are Clic-R #96135 and are green
the ones on thd fuel pump and fuel pump plate are #96145 and are black
all stainless screw type are Breeze #3704
you should be good to go
:popcorn:
When I did my fuel lines I found that the factory clamps weren't tight enough to prevent me being able to pull the fuel line off the new filter. I fitted some miniature stainless clamps I bought from McMaster-Carr (I have an assortment for my other bikes) to make sure the hoses are nice and tight.
There are many stories about the fuel hoses coming loose in the tank causing the engine to shutdown. Good hose clamps will prevent this.
Eric
Eric;
be careful that the clamps you use are ALL stainless steel
some use stainless bands and steel screws
not good with Ethanol fuel
:popcorn:
Really nice thread, great work with the schematics!
1 - 13 of 13 Posts
