I've read several reports where it mentions the new 1090RR has a fuel level indicator. It shows a picture where the temp gauge is....
"The two LCD screens have been enlarged and have even more functions. There is now an indicator showing which gear is engaged, the fuel level, the speed, the hazard key, the water temperature, and the chronometer function, with memory of laps and of times. The instruments are already set up to use a system for monitoring tire pressure."
This was taken from MV Agusta UK, but also says the same on the US site.....
I don't see anything in the manual, am I missing something ?...your comments are most welcome, thanks
Fuel gage
With 3,000 miles on my 1090RR, the only fuel indicator I'm seeing is at around 150 miles on a full tank, a warning appears in the dash and starts counting the number of "miles traveled on reserve".
I guess the programmer's translation from Italian, is "fuel level just entered reserve, turn on the warning display"
What I'm looking for is the bastard who programmed the damned trip meter setting routine. This was one devious and cruel bastard!
Dick
Dick
Totally agree with you about resetting the trip computer....I'm doing the factory visit in November so will be asking then....!
the 1090RR I took for a test ride had a fuel gauge in the bottom left hand corner of the screen dunno if this helps? have you tried phonning the dealership to ask about it?
