Seem to have developed a fuel leak from the tank vent after riding, regardless of gas level. 20-30 ml of fluid in pan each time. I have removed canister without any difference. Any suggestions? Thanks
Had an issue with my fuel vent too. It was leaking gas out the top onto the gas cap. Dealership replaced it under warranty.
Thanks. Fuel is leaking out of the vent after I ride. Good steady dripping into a pan I placed underneath the bike. Even happens after riding for a good hour.
fuel leak
Bike is now back from dealer. The problem that caused gas to leak from vent hose on right side was a fractured gas tank. Apparently a water vent runs through the tank and when cracked allows fuel to leak. all costs covered by MV!!! Entire tank replaced. Happy customer.
Hey toml, how long did the dealer take to fix your leak? I'm having a similar issue. Not a lot, just a dribble right now, from the looks of it, coming out on both sides of the back of the tank onto the small tank fairings.
