I can't seem to find a listing for this part. I believe mine needs to be replaced. Does anyone have a part# they could share?
check out Star Twin for part numbers.I can't seem to find a listing for this part. I believe mine needs to be replaced. Does anyone have a part# they could share?
I was thinking so. I appreciate the responseIt appears it is only available as an assembly: 800093340 FILLERCAP WITH KEYS
Technically, it is not an o-ring. It is very reminiscent of an automotive rubber thermostat gasket.What O-ring you mean?
I think I'm going to go aftermarket non-locking. I will source a gasket in case I ever want to swap back to stock.I would by a used cap and rekey it.
Maybe it's just me living in Philly but I would worry about some hater putting something in your tank.You can get a quick release cap. They look trick, but if you park your bike outside unattended, people might steal your petrol as there is no key.
Also, if you don't close the cap properly it can by sucked out by the wind (but will never happen if you make sure you close it properly).
They are a lot cheaper than getting a whole new assembly from MV.
Chris
This is what I did :grin2:You can get a quick release cap. They look trick, but if you park your bike outside unattended, people might steal your petrol as there is no key.
Chris
