1 - 2 of 2 Posts
FS: Brembo Monoblock & Supersport Rotors
Hello to everyone
For selling is a set of Brembo Brake Racing kit, consisted from Calipers, Rotors Supersport and the master cylinders.
(the Disks are like new, calipers and Master Cylinders are used for aprx. 15.000Km-mixed road&track, pads are new in pack)
set CALIPERS : 350 euro*
- set (left + right hand) Brembo Monoblock M4 34 Radial Calipers, color titanium, with Brembo brake pads for road use & high pressure brake lines
set of ROTORS : 300 euro*
- set (left + right hand) of Brembo SuperSport Brake Discs. 320x80 mm, 34mm braking rotor, 5,5mm thickness - Works only with radial Brembo Monoblock callipers
set of Bolts : 50 euro*
- 4 x Titanium screws (M10x58)
set of Pads : 50 euro*
- two sets (2 couples for 2 disks) Brembo - 07BB30RC brake pads - Racing Carbon-Ceramic brake pads for track use only (dry conditions)
- two sets (2 couples for 2 disks) EBC - GFA447HH sint brake pads for road use
BRAKE master CYLINDER : 150 euro*
- Brembo Radial Brake Master Cylinder 19x18 Forged, fluid barrel
CLUTCH master Cylinder : 100 euro
- Brembo Radial Clutch Master Cylinder 16x18 Forged ( little damage on lever), fluid barrel
Additional for F4 S models, set of Marzocchi lower forks at 50 euro*
(only with all of the above parts, you only need the front wheel axle of the R models)
*: plus shipment, items located in Athens, Greece
Thanassis
I'll take set of bottom fork, if it NO NO leak or rock chip that make it leak before you change it out, I am in, plus interest on set rotors please check your pm
1 - 2 of 2 Posts
