1 - 11 of 11 Posts
Discussion Starter #1 (Edited by Moderator)
Hi
I am wondering does anyone of you are using this kind of front wheel lift (frame head lift):
youtube.com/watch?v=kyGl7YNDczs
the question that comes to my head is will it fit F3 in the matter of front fairing (cowl). I mean, does the shape of fairing will not cause, that the lever will touch it and break it when lifting bike up?
I already have rear wheel stand and considering front wheel lift.
Anyone using this kind of front wheel lift?
I don't think the MV has the hole in the steering stem to receive the pin for this stand (the 4 cylinder bikes I own do not).
There are stands of a similar style available for the front of the MV. They have a cradle that the steering stem sits on, rather than a pin.
I use a pitbull front end stand like this, with the #15 if i am not mistaken, works perfectly fine.. will check it again tomorrow to make sure there is no interference for you
Ive had two of them although no longer but im pretty sure the stem size as i recall is 27mm for the front stand, i could measure it for you if you like as I still have the stand
I use a car lift and 3,000 lb rated Kevlar lifting loops
Glad to learn the later models have a hole in the steering stem to accept front stands.....the first gen bikes that I have do not.
Front fork lift stand works on the F3, the inverse V shape of the intake clears my stand by a few mm.
1 - 11 of 11 Posts
