1 - 14 of 14 Posts
hi all
i did a search on this site i can't find anything about a front paddock stand and the one i have is no good
so who makes the easiest one and the cheapest one
emoto have a section for paddock stands but its not a link to anything and theres no price quide i could find
i need to get one quick as i'm having this front air leak while breaking her in and i've only covered 350miles so far
and i'm loving it
no i've got my footpegs adjusted
i din't realise they where height adjustable as standard on pivot mount it looks just like a casting mark that don't work there for show
another tick for the mv in my books
just need to sort the slippery pegs out
this site is excellent and i hope to give more imput once i suss my self out with the bike properly
but in the meantime i'll keep reading and learning from you guys
ride safe
jas
The content of your post indicates you just need to get the front in the air so you can get the wheel off. If you have a garage, just get a pair of ratchet-style tie-downs a couple of soft straps and crank it up from the rafters. Or build a ramp, hang the bike with the soft straps and a couple of standard tie-downs then slide the ramp out. HTH
I read in this forum to use a tall step ladder with ratchets and it works great. I then took some but not all the weight off by lowering down on a bar stradeling two jack stands.
I bought a pitbull front stand, that lifts from the bottom triple clamp. It allows you to remove your forks and/or your front wheel. Spend the $140 and get one. I tried the rafter thing with my friend's 1991 Nighthawk, and it was nerve-racking. I would NEVER do it to my Aprilia. It is so unstable.
You just need to get a "universal" front stand that has a flat metal plate on the up rights.This is normally for conventional front forks and used by Japanese bikes.
All you need to do is adjust the length of these (universal ones have adjustable front feet) to fit under the brake caliper mounts rather than the bottom of the forks and voila!. My universal ones I use for all my different bikes, it has rubber on top of the flat pads, so no scratching and costs about $150.
Unfortunately, pitbull does not, nor has any immediate plans to, make a front 'triple-tree' stand for the MV. The problem is MV's don't have a hole in the bottom of the lower crown, and it's too thick to use the Ducati hook style.
postman_bat said:
hi all
and i'm loving it
ride safe
jas
This should help:
James - MV Agusta FAQ
Unless your garage is on the verge of collapse, the bike won't come down unless the rafters do... and the bike will be rock-steady if you secure the rear end of the bike while you're working on it. The stock MV rear works perfectly for this purpose.
The "rafter thing" allows you to remove the front wheel, the forks, the brakes from bikes with absolutely no worries whatsoever and an added plus over using a stand is there is NOTHING in your way while you're working on the bike.
Another tip... any time the front needs to come off it will be in my garage, so I don't need a "pit stand" and since I already have the rear MV stand and a Pit-Bull rear stand, I got Pit-Bull to make a pin to fit the MV front axle. Now the MV stand goes on the rear, the Pit-Bull goes on the front and I can have the bike in the air and the forks off in less than 15 minutes. The custom-made pin cost about what the shipping does on a front stand.
Fast By Ferracci has stands in stock. I have already used mine and can verify that they work properly and reliably. It lifts the front up via the caliper mounts so you can use the wheel drop-outs to remove the front wheel, etc. It works great. Call their parts department or go to their web-site.
Why dont you try a Abba stand, i have one with connectors for my Mille and MV.. connects to the swingarm pivot.. then you can either easily lift the front from rafters or compress the back with ratchet strap from rear to stand.. pulls down the back..
I use the Pit Bull standard front stand. It fits right under the brake caliper mounts and securely lifts up the front end for easy front tire and brake caliper removal. If you need to remove the forks, however, you need to explore other options.
Joe
I do the same, but I like to put some zip ties around the lower fork tubes and tie them to the pins on the stand. Once the axle is out, the lower fork tubes can freely rotate and I wouldn't want a good bump to twist one and knock the bike off the stand.
Alex
Joe
altoon said:
I do the same, but I like to put some zip ties around the lower fork tubes and tie them to the pins on the stand...
Alex
Profound advice, Alex! I'm gonna start doing that from now on.
Joe
1 - 14 of 14 Posts
