1 - 20 of 29 Posts
They look real good fella are u doing them for the lower holes as well I'd like a set I them fella if u feel like banging out some more I'd make be get them anodised darker to match frame let me k ow if u will and cost fella
Adam,
If you leave your bike parked up around Weston you do know Jeni is going to pinch them frame plugs don't you?
jimboF4
Nice work Adam..
Thanks all...
Brian, you were right, probably a nightmare to turn that face on the lathe, as you noted before I would need 2 setups for the different plug shapes. I didn't find left to right were different though - unless the lower ones are ??
The main body of the frame plugs and the fixings were done on the lathe first, then I ran it through the mill to drill the smaller holes and shape the face. A quick polish and it was done...
I'll make the plugs for the lower holes in the week, if it's not to cold - it's freezing in the garage !
Jimbo - Hmm, best not ride it to the pub then.....I still have your chip sat on my desk here......
Adam
Don't worry you will always be safe down the pub with me to keep an eye on her.:)
It's when you are out riding on your own and spot a mad woman on a Brutale in your mirrors that you need to panic. :brutale:
jimboF4
Thanks all...
I just finished building a CNC mill. Designed and built the electronics and all the hardware for the 3 axis. It works very well.
The main body of the frame plugs and the fixings were done on the lathe first, then I ran it through the CNC mill to drill the smaller holes and shape the face. A quick polish and it was done...
I'll make the plugs for the lower holes in the week, I just finshed the 3D drawing for the mill software.
Adam
Yeah Adam..you did a good job there, they look great. No they aren't different from left to right...just 'upper' and 'lower' have different face angles. The other ones I made http://www.mvagusta.net/forum/showthread.php?t=34819 are different from left to right. Anyway good to see another 'lathe freak' on the forum.....! Cheers Brian:)
I may be a lathe freak but I have a way to go to catch with you. I am only just begining to learn how to use these tools ! It takes me a while to sit down and figure everything through before I start.
How do the orings in your oval plugs stand with the heat, the frame gets very hot down there, at least mine does.
I used a split aluminium band on the normal frame plugs, I guess it should be ok, if not maybe I'll use stainless steel...
Adam
Finally got around to making some frame plugs today..
I made them out of 6082 aluminium to match the design of my stainless bar ends....8 hole
Adam
Very very nice - and you definately have talent ! :yo:
(They look very similar to my Motocorse frame plugs..though I am certain yours cost much less ! :laughing:)
Thanks !,
As for any similarity I think you will find any frame plug has to be of a certain shape so they will all end up looking the same !
Mine have 8 holes, to match my bar ends, the Motocorse trade mark is 9 holes so they are completely different.
Here are some 10 hole plugs on Design Corse..a site sponsor...
http://www.designcorse.co.uk/Mv_Agusta_Frame_Plugs/MV_F4_Style_Frame_Plug_Kit
Adam
Lovely work mate. Form follows function, so it's not your fault if your plugs look like other plugs :f4:
cheers,
Hoppy
I have the Design Corse ones in black. Like em.
1 - 20 of 29 Posts
