Status
Not open for further replies.
1 - 6 of 6 Posts
Here are instructions on fitting a Mitch Hub.
Pictures are supplied by MVBoogie,because I
am too lazy to do it myself.
Any questions please ask.
Grease used is Penrite High Temp Bearing Grease.
Never mix greases.
All torques are MV specs.
Correct chain adjustment is critical.
Service hub at MV's service schedule.
1/Loosen rear wheel nut/sprocket side nut and support motorcycle safely.
Remove rear wheel.
2/Loosen pinch bolts,rotate hub with C spanner and remove chain.
3/Remove sprocket carrier and spacer.
4/Remove 2 caliper mounting bolts and caliper.
5/Remove C-clip.
6/Remove caliper carrier.
7/Extract hub from swingarm,use plastic or wooden wedge
in swingarm split if hub won't slide out easily.
Clean all parts.
8/Comparison of old and new hub.
9/Fit new hub with light smear of anti-sieze in
swingarm.
10/Re-fit caliper carrier and C-clip.
11/Roll Oring supplied over the axle.
12/Re-fit axle with light smear of anti-sieze where
axle meets wheel side bearings.
13/Re-fit and tension caliper.
14/Re-fit spacer and sprocket/carrier and chain.
15/Adjust chain to MV's specs.
16/Tension pinch bolts evenly.
17/Re-fit wheel and tension axle nuts.
18/Fit safety clips.
Safe riding.:)
2005 F4 AGO 2017 TVL RC
that looks easy. Has MV done anything to the newer bikes to correct the hub failure? I have a 2012 brutale. Is the hub the same as the older models?
No, that is a different one and should be better.
Great work Mitch!
On the wheel side they put in a needle roller bearing and reduced the 2 Row ball bearing to a single row.
Mitchys hub has a wheel side arrangement of 2 sets of double row ball bearings. They are also bigger and stronger ball bearings.
A bullet proof set up proven on the road.
Joe
Does the come with that fancy Mitch's Motorcycle stand, too?
:D
1 - 6 of 6 Posts
Status
