1 - 3 of 3 Posts
Took most of the day but turned out a rewarding job. Used the membranes that go under original grips so i can use what grips i like.
Found a spare bit of carbon & plastic so trimmed it to fit under the clocks, looks like it grew there...
Be out tomorrow to see if they make a difference
...very interested to read your feedback on the heated grips. I am mostly interested to know if the tips of your fingers will feel some heat or not.
Kham. I was very impressed today with the results, kept my hands lovely & warm & even the tips (apart from my thumb). Only negative was the left one was not as warm due to it being stuck directly to the metal. I rectified this when i got home by removing grip & membrane & placing some heatshrink on the bar before the membrane & resticking the grip. Recommended mod & a good addition especially in the cold. I had alpinestars goretex winter gloves on & the heat went thro these no problem.
1 - 3 of 3 Posts
