Finally!
Ive asked a bunch of questions since getting this thing like 8mo ago and finally rode it about an hour ago!
If this forum and its members didn't exist or wasn't in my language id have given up and sold the bike off before now!
I especially appreciate the extensive help ive got from Dansoarr in helping me deal with the ecu and ecu studio which is user-unfriendly.
So...
I took it for a 20mile spin trying to scrub the tires in do some hard pulls for break in and bed the rear brake pads first but the bike was killing the engine everything id try to manually rev match for a down shift and did a weird rpm auto blipping rev thing when trying to take off from a stop so I came back home and got Dansoarr on the horn and ended up having to turn off the blipper on the ecu. took it back out and was shredding on it for another 20 miles until my front fender vibrated the bolts on the right side completely out and the left side had 2-3 threads left! I managed to limp it home but now looking for new bolts and going to loctite them. It still has crappy throttle response when blipping for downshifts and the clutch does this weird thing like it jerks forward in your hand like somethings going on inside the basket when you pull it in but the throttle is smooth on/off no bucking which is great, won't have to worry about the soggy throttle on downshifts once somebody sells me the blipper sensor
Observations
-The abs on normal is total shit. running on race its still pretty bad but still useful, NOTHING like my Ktm, ducati or zx10 was. at least I can turn it off
-my exhaust with the db killer sounds heavenly, especially with a QS, haven't taken the baffle out yet and don't intend to unless at the track.
-the front brake master cylinder is total shit. same issue as my new gsxr 1000 and many other bikes, have an rcs19 on the way for the gsxr, will put one on this if it lives up to my expectations
-rear brake feels good, you can tell its heat soaking from the pipe and back/side of block so im going to shield/insulate it
-bike is WAY more comfortable than I thought, my rear sets ended up being lower than original even on their highest setting so im sending them back and getting something else
-my rear shock feels ok I suppose, need to soften the compression a few clicks
-oem forks seem way to fast in comp & rebound but at maximum they are probably close to ideal
-bike feels lighter but honestly, not dramatically lighter or quicker steering than the gsxr 1000, just a lot shorter and thinner. Not complaining but im not wow'd either. im also on DSC SC1 & sc2 tires not the junk that was on their either
-gearing feels a little tall, running a 180/60 rear as well, a -1 might fix it also part of a 520 conversion for some weight and reduce losses.
-Feels like it needs more RPM, like another 2k
-power is honestly, underwhelming. In my mind I was expecting this to be making around 130whp today with the race exhaust, race filter & "kit" ecu flash, it "feels" about the same total speed as my zx6r's and r6 were and they were approx 110whp. This needs to be addressed!!!!!
Overall, its a very pretty bike, it needs the chassis setup better, lower gearing and I guess a custom dyno tune at this point. I got a very good deal on the bike but it stills needs another 2k or so into it and its already significantly more $$$ than my new gsxr 1000. One of those cases of terrible value proposition but hopefully the happiness ratio is better. Its definitely different than the gsxr in the fact I can put down 100% of its power on these country back roads and really exercise the bike.
Have 2 track days coming up, the 2nd & 18th, seems like both the gsxr & mv will be ready in time. need to get the blipper on the mv as how it is now will be locking up the rear wheel.
Need to get another 60 miles on it so I can change the oil & filter and tighten the chain before the TD's.
So...
Observations
