1 - 2 of 2 Posts
Has anyone installed the Ferracci Carbon slip ons? Wanted to know how you like them. The sound and performance difference from stock. Also did you get the ECU and the Cat bypass pipe. Did this help with the overheating?
Thanks!
The catless midpipe will not fit the 312. The 312 has a one-piece header. There's been plenty of discussion on this in other threads, but if you want to remove the cat, your choices are either getting the replacement header with the matching midpipe or removing the catalytic material from your existing header. I wouldn't recommend the latter.
1 - 2 of 2 Posts
