1 - 3 of 3 Posts
Hello There, recently there has been an issue with the RPM sensor on my bike F3 800 ( 2017 ) it won't start and shows "Fault RPM Sensor" warning on dash, now even though I got the new RPM sensor installed it still won't start and shows the same error. Did any one faced similar issue, looking for some suggestions from fellow F3 owners....about how I can fix my bike.
Thanks!
ChimanSareddy
Weak battery and failing sprag clutch will cause that fault code. do a bit of search and reading for much prior discussion..
1 - 3 of 3 Posts
