Easy cost effective repair to make this problem better than new.
This problem is easy to fix, but make sure you check this out first!!
:smoking:
What's the best way to fix this ade?
Drill the brackets and put in new pins?
I know i'm responsible for breaking one of the little buggers... but i lay blame on others for the rest.
Stiv[/quote]
Where the pins have broken off it will have left a visible scar,
I have simply drilled the brackets and then screwed in a shortened (thread about 6mm and shanked) allen screw 4mm in diameter (I think!) most of the ones I have done have even cut their own thread into the bracket too as the bracket is made of a soft alloy.
You only need to have about 5-6mm of thread on the allen screw.
Make sure you don't drill right through the bracket (Not that its the end of the world in you do anyway) and once screwed into place up to the shank of the screw using a bit of loctite, carefully cut the shanked part of the allen screw off screw off so all that you should now have visible is the peg in essence leaving about 3-4mm protruding.
Finish the job by rounding off the edges of the newly fitted peg using a small needle file and there you have it
:drummer:
This home made peg will never break off and providing you are careful it will stay put and not deteriorate if its made from a stainless steel allen screw.
Just remember to make sure the shank of the allen screw you intend to use is a nice fit in the reciprocal socket on the electrical plate.
$70 saved immediately and the job will last forever and no more indicator hassles
Just be very careful when you go about this job and don't rush it, make sure you are able to grip the fairing mount securely without damaging it too.
Its really no big deal just some care is all that's needed.
I hope this helps some of you make a cost effective repair, and always check both these pegs are in place whenever removing the upper fairing.
NEVER
over tighten the long screws that locate the upper fairing as this is the prime reason for these pegs breaking off in the first place, as the long upper fairing mounting screws (1 on each side) go into the electrical plate at an angle, effectively pulling the fairing brackets forward against the pins.
