1 - 19 of 19 Posts
Those do look nice.
Does anyone know if these will fit on 2006 front end?
Rear yes, front only with spacer modifications....but yes, they could be made to work.
If these are off an F3 Oro they won't fit a 2006 F4 1000S, Senna, Veltro, or CC without mods. In addition, the F3 rear wheel (except for F3 Ago) is 5.5" and most F4's (except for F4 Ago) use a 6" rear wheel.
If the OP can provide a part number of the wheels, it would make things a lot easier for interested parties. Are you sure these are forged?
Ah, I was going on the info you posted in the fb ad. Here you do mention they are 6". My apologies. I've put older wheels on a newer bike but not vice versa. The standard 06 F4 uses a 35mm axle and the newer bikes, 25mm dia. Other than changing the spacers to one with a 35mm ID, not sure what else needs to be done, sorry.
No, not if the rear is 6". In my experience, I've always seen F3 forged wheels to be anodized and +10 F4 forged to be painted. Adding to the confusion, the F3 Ago rear wheel is 6" but I believe also anodized.
Discussion Starter #15
Here are some MV's that came with this type of wheel.
All with lightweight forged wheels.
Hello
Will these fit a 2006 Brutale 910S?
thanks.
Discussion Starter #19
Hello
thanks.
Rear, yes.
Front, not sure if it's a straight swap.
I think the general consensus is that earlier MV's had a different size front axle. You may need to swap bearings or axles or spacers if it isn't a straight swap.
Not sure if you're up to messing around with that. I'm happy to take any measurements you need.
1 - 19 of 19 Posts
