1 - 6 of 6 Posts
F4 sticking throttle
Hey guys havent been on much lately, been terribly busy.
Anyway I got a chance to go riding last weekend and notice that my throttle does not return to 0 position, it sticks. Mind you I had previously released the left-side throttle spring to relieve pressure on my wrist whilst riding. Well, now it doesnt return to the 0 position. This really appears to be a mechanical (lubrication?) issue and does not relate to engine throttle sticking (what I mean is, it appears to be the cable or handle or something).
I did a search on here and didnt find any relevant posts. Anyone have this issue and know how to resolve it? I am sure if I put the 2nd spring back into tension the throttle would return, but then Im stuck with the stiff wrist problem. After I first released the spring, the throttle returned normally, but it no longer does.
I feel as if a squirt or 2 of WD40 somewhere might do the trick. Thanks in advance for any advice you might have.
Similar thing happened to me. Mine was a simple fix - the rubbery part of the throttle had slipped onto the bar end. I drove the bike to the shop and all the guy did was slip the rubbery part back into place.
May not be the same problem as yours, but worth a look. Good luck!
thanx Brat that just might be the problem since thats exactly what it felt like and I kept eyeing the rubber handle. I'll give it a look when i'm out next.
Try slightly loosening (backing out) the bolt at the end of the bar which secures the counter-weight. Slight over-tightening causes the internal wellnut to overexpand and bind, thereby preventing full throttle release.
It was a pretty nice thing to have on the freeways though - CRUISE CONTROL :yo:!!!
But sucks big time on the twisties.
Hope that's it cuz it's a quick fix. Good luck!
This worked perfectly, I loosened the end bolt a bit and all was back to normal. Thanks lewolf.
1 - 6 of 6 Posts
