I haven't gone back to re-read the entire thread, but I got the impression you cut into the harness and soldered the diode in. I was thinking of simply inserting it, as a bridge, directly from pin-to-pin between the relays. A friction fit.
Adam can you confirm if a setup like this will work?
I carefully filed down the end of each prong on the 3A diode and friction fit it per SilentService's method above. Each prong is sitting securely wedged next to wire ends.
I haven't fired anything up yet because I don't want to blow the bike to the moon.
I'll shrink wrap it all and electrical tape it for backup. Good to go or am I at risk for catastrophic failure?
The side of the diode with the bar on it, ie the side you have connected to the red/white wire needs to be connected to the low beam side, the other side to the high beam.
It depends on your year of bike but it looks ok.
If it is wrong, it would work the wrong way around, just switch it on and try
I soldered mine to the wires but if it is a good fit then I guess it's up to you....
I checked the headlamp relays and they have no detail on them to specify the rating - just the part and pin numbers.
The relay holder has a bocsh part number and is for a bosch 'micro' relay. These are rated at 15 to 25A so will be fine for the ballast which tops out at just 6.5A at startup dropping to a mere 3.4A after 12secs.
I'll see what the widget looks like when it turns up - I know its semi potted and uses a transistor to switch. There might be room under the right hand electrical cover next to the horn.
Looks like the connector block in the same area links to the starter switch as well.
A forum community dedicated to MV Agusta motorcycle owners and enthusiasts. Come join the discussion about troubleshooting, maintenance, performance, modifications, classifieds, and more!
