Okay, here is my dilemma. I got hit with a Vehicle Test Notice for exhaust noise. Naturally from there took off the aftermarket pipes, put on the oem's and booked a sound test. Bike is meant to read 94db @ 6250rpm's but instead was 96db. FAIL.:jerkoff: I am guessing the insides have collapsed.
Is there anyone in Melbourne kind enough to lend their oem pipes to get the test done. I have a 2000 750 F4S.
PM Sent
(edit) - They are stock off an 02 750 - i havn't done anything to them so if they don't pass don't look at me
snohman and twizel... you guys are awesome :yo:
PM Sent
If it doesn't work out with 'Snohman' you can borrow mine.
Wow.. Snohman, Twizel. Guys, that is great. This is going to save me alot of headaches. Snohman I will be in touch soon to grab your 02 set. Thanks again. :smoking:
Okay, the update is.. Snohman, thank you so much for the lend of the pipes. I put your pipes on and they sounded identical to mine. I did a bit of google searching and opted for the $2.50 steel wool remedy. Well it worked. Thanks again guys for your help :)
