1 - 6 of 6 Posts
Guys, does anyone know if there is a difference in the exhaust headers / mufflers between the 2010 F4 and 2013 F4R ? :jsm::jsm::jsm::jsm:
Discussion Starter #2
And..................................is there anybody out there :surprise::surprise::surprise::surprise: just bumping up as I need the information, are they all the same?:jsm::jsm::jsm::jsm:
The 2013 is a single piece header and CAT, where the 2010 is multi-piece headers, collector and CAT. The 2010 you can fit a cat free link pipe, 2013 cut and weld.
Not sure if it changed after 2010 or 2012.
Hey D, thanks for that however I should have been more specific after seeing your post, our plan is to "cut down" (at the point where the flatten section "joins" just under the seat) a 2010 muffler set up to fit on 2013 headers; basically we want to then add to the cut off muffler an SC Project look alike single pipe (if this makes sense :surprise::surprise::surprise::surprise:) to complete the project! assume from your view that the 2010 "muffler end" will hook up ok to the 2013 headers? :jsm::jsm::jsm::jsm:
Ahh. I had check. It might be pre 2010 that were separate parts. Post 2010 single piece headers.
I had a 2012 single piece header (de-cat) feeding a 2015 silencer and exhaust valve.
Thanks D and it looks like we are green for go!:smile2::smile2::smile2::smile2::jsm::jsm::jsm::jsm:
1 - 6 of 6 Posts
