well, its been a little slow with life and work getting in the way of my spannering time! but I have done more work on the 'FranKenBike'
Motor vehicle Automotive lighting Automotive tire Crankset Vehicle
Frame off the 750....
Motor vehicle Light Automotive design Automotive fuel system Automotive air manifold
And onto the 910 with front end still attached..
Motor vehicle Automotive tire Automotive design Automotive fuel system Hood
910 Throttle bodies fitted along with my stick coil modification to run on earlier type ecu wiring loom. Battery bix to go in and make off new battery lead terminals then i will crank it over without fuel to get some lube around the motor.... Next job head bearing conversion to taper rollers and Ago Showa forks when they have had refresh...
Discussion Starter · #3 ·
its a little cramped as I only have a single garage so full lift would restrict me a little. Been looking at the Abba Skylift though as it takes up less floor space and it has wheels so bike can be moved whilst on it.
You would certainly get the height with the Abba. Regular daily use stand offering low to medium low lift is the Bursig. Easy to roll about and engage. Tad less expensive than the Abba and more practical.
Reactions: JensonF4
