1 - 19 of 19 Posts
Has anyone had any issues regarding the wheel nut coming loose on the sprocket carrier sde?
A couple of years ago I was riding when I suddenly found my self effectively free-wheeling. The wheel nut has come loose which allowed the sprocket carrier to disappear into the undergrowth - never to be seen again. The bike had recently had a rear hugger fitted so I came to the conclusion that the nut had not been torqued up properly. I managed to obtain a replacement carrier complete with cush drives plus a new circlip. I made sure that it was torqued to the correct figures (200 to 220 on the chainwheel side and 220 to 240 on the wheel side).
About 3 weeks ago the bike was due for its MOT and there was play showing in the rear wheel. At first it looked like a bearing issue but it turned out the nut was loose again. The bike has done about 30k miles and has done no more than about 3 or 4k miles since the previous incident.
Has anyone experienced this?
Did you have the retaining clip installed?
If you torque your cush drive to spec and have the retaining clip in place and it is coming loose that's a sign of your bushings wearing out. This usually doesn't happen on the old style (round bushings) but on the new style. Seems very odd that this would happen after you replaced it with a new one... when was the last time you serviced your hub?
Discussion Starter · #4 ·
Hello Tapatalk
As you know the early F4s had hub issues and mine was replaced at around 21K miles
When you say retaining clip I assume you mean the circlip around the wheel nut and sits into a hole in the axle ? Yes a new one was fitted after the first incident because I wasn't sure if the existing one had been damaged in some way
Discussion Starter · #6 ·
Sorry - I got your ID wrong but the message remains the same
How often should the hub be serviced?
Do you mean the circlip that fits around the wheel nut and then sits in a hole in the axle? Yes a new one was fitted after the first incident
Yes, that is what I mean. If that clip was intact, then the nut did not loosen. It cannot.
There will be another issue that is causing wear in the "stack" of components from the sprocket nut all the way through to the wheel nut. There has been much discussion about this in various threads. It is unusual in a First Gen bike, though.
The maintenance interval is every 7500 miles.
482603
Discussion Starter · #8 ·
A new upgraded hub was fitted when the bike had done 21K miles but the hub has not been touched since then so there maybe some other component that has worn since then. Looks like it needs to come apart for a deeper investigation
Discussion Starter · #9 ·
By the way the nut did come loose on the first incident and the circlip was still in place. It did occur to me that the circlip might be damaged in some way so that it wasn't being held in the hole in the axle....but it looks like the cause was something other the the circlip- still a bit strange though
Wing Nut
I was on a ride with a friend whose nut came off whilst riding through a town.... he had neglected to install the clip. Luckily we found the nut, put it all together and then secured it with a split ring key chain to get home.
Never heard of another first gen doing this if the circlip is in place.
Sounds like your circlip isn't engaging the hole in the axle.
Reactions: Figifister
Discussion Starter · #11 ·
Hello
Yes the first time i happened we also found the nut very easily complete with circlip but the sprocket carrier being heavier disappeared into the undergrowth. When the sprocket carrier was replaced i fitted a new circlip and made sure it was engaged but it only goes into the hole in the axle a small distance. So it is even more of a mystery why it has come loose again. Its been suggested that there is another issue somewhere.
Like Ed said, You can install the clip without engaging the hole that's easy to do and you have to do a double-take and make sure that it's in place. Just because you achieved the proper torque value doesn't mean that your inline with a hole. You may have to loosen or tighten slightly to have the axle hole line up with the nut hole. I secure my circlip with a piece of welding wire twisted around itself.
Yes you need to take apart the hub and inspect it according to the tolerances in your service manual. Mitch would be a good person to talk to if you have any specific hub related questions. He sells a high quality Hub replacement.
1st let's get the names correct
The wheel nut is on the RIGHT SIDE OF THE BIKE
IT HAS A LEFT HAND THREADS
The sprocket nut is on the LEFT SIDE OF THE BIKE
The and has RIGHT HAND THREADS
They both use a tapered 55mm socket
Discussion Starter · #15 ·
Yes I am aware of that and I am almost certain from memory that we did align the circlip - i was doing the job with a friend of mine who had the the exact same bike...
STOP REPLACING GOOD 1ST GEN HUBS WITH THE POS 2ND GEN HUBS
in 2015 the Factory race bike used a 1st Gen hub and cush drive
In 2018 the Factory went back to basically a 1st Gen hub and cush drive
TELL YOU ANYTHING?????
Discussion Starter · #17 ·
What on earth are you talking about? The hub was replaced because it FAILED and it failed suddenly. I was one of the lucky ones - mine lasted for 21k miles whereas some people had to replace it at 7k miles. The replacement was an upgraded version of the Gen 1 hub not a Gen 2 hub.
All 1st Gen MVs use the same hub
750s had a different CUSH drive
That was fixed with the "quick change cush drive"
I'm the one supplying the Forum with hub bearings
When you squids torque the pinch bolts to 28-32 Nm
Discussion Starter · #19 ·
I had to replace the cush drive carrier because it had disappeared into the undergrowth when the incident took place I managed to source one from an EV03 which was being broken for parts..
1 - 19 of 19 Posts
