hello
just gut a new 2013 F4 white .
when its time to change oil
i need your recommandations please
1. can i use Valvoline Full Syn 10w40 ? or semi syn 15-50 ?
these are the only grades i can find in my country.
any issues with over heating ?
2. what is the compatible oil filter i can use ? cross reference with yamaha or honda or maybe K&N ?
3. is it normal for the temp to be almost full way (1 or 2 bars left to reach top) ?
thanks a lot
Older F4´s had a tendency to overheat at low speeds. However,from 2010 onwards this is no longer the case.
The temperature reading in the instrument panel is usually 1-2 bars above the horizontal line. Should not go higher than this.
thanks pepe for your reply
james , i am from egypt
so what about the oil ?
anyone tried to use one of the mentioned grades ?
Welcome Maximum2 :D
And the full synth 10w40 should normally be fine. I used motul with that grade and it was fine. Maybe the tech experts over here can say something about it. And otherwise you just have to order it...
An F4 in Egypt :jsm: ?
Man, you really got balls :yo:.
hi cherche
ever been here before ?
its not very popular over here
ducati , harley is very popular though
i myself own a vmax1700 along with the mv agusta .
so any solution to the filter and oil questions
