Well after the exhaust valve error solved, now new error on the dash - gas position error - and had the throttle stopped a few times, fortunately all at low speed and easy to stop. Normally I stop and start again most of the times and stays normal. In my opinion it's a bad/dangerous problem so the bike is stopped till I find a solution I dont want this to happen on the highway.
I found that some had a new map installed, others changed the complete throttle and others passed with a simple "grease".
Does MV assumed this has a problem "warranty issue"?
Let me know how you handled this issue and to be honest till now I ve only heard this on the F3 but probably a similar issue.
Thanks for the answer.
Considering my F4 is from the first 2013 I think an upgraded throttle is the way to go!
Does anyone fitted any aftermarket throttle control?
I ve checked domino but don t think they ve for 2013 F4!
