1 - 3 of 3 Posts
Dear all,
Does anyone know the details of this particular relay.
Whilst I have the part number (800088572) my local dealer hadn't one in stock, I wanted to buy same on Amazon or similar and my instinct feels I need a 4 pin 25amp normally on, however there are various options described on various sites which confuses the hell out of me... eg:
12 Volt, 25A Micro Relay with resistor. NO contacts.
12 Volt coil with resistor to suppress back EMF.
12 Volt, 25/15A Micro Relay with resistor. CO contacts.
4 Pin 25A Micro Relay 12V Normally Open On/Off
- Automotive & Marine Applications by Ripca
Durite Relay Micro Change Over 15/25 amp 12 volt with Diode
12V 30 Amp Micro Relay Make And Break 4 Pin
With Diode 160364 by HC-Cargo
Can anyone help me out with what I need to order?
Tont
(ps I'm going to order a bucket load as the originals seem to corrode very easily - I the UK that is!)
Dear all,
Tont
George,
This is the fan relay also headlight main beam and headlight low beam relay.
Be careful buying new cheapos as they may not have the back emf protection.
I have some here..You know how expensive they are ..A cup of tea !
Joe
1 - 3 of 3 Posts
