1 - 14 of 14 Posts
I've been looking for some dyno numbers on the '07 f4 1000r.....anyone know the range of what they typically put down, with or without mods? How about the 312r?
:mouthwate
I heard 174 at the rear wheel, but I have never seen documentation on it.
174hp at the flywheel actually, at the crank if you preffer. Maybe 160hp or less at the rear wheel. It's been posted before, just do a search.
after a search looks like ~160 rwhp for the f4......
Expect something like the following:
1000S==150 bhp
1000R==163 bhp
312====170 bhp
All figures are approx due to different dyno's, days, operators etc, but these seem to be a reasonable 'average'
A few 'truths' :blah:
Everybody thinks the dyno they were on is correct, UNLESS it doesn't give what you expect.
A dyno that gives better/higher readings will get more business than a 'truthfull' dyno. Ferracci's dyno gives good bragging rights :naughty:
Comparisons when swapping stuff like exhausts etc should be done on the same dyno and preferably the same day
I have a chart that shows mine at 162, but with power commander and new mid pipe (no cat) fitted it now shows 167. This I understand is at the wheel.......
Yeah Mike's numbers seem inline with both what MV is qouting and what comes up actual (at the wheels). I ran my 1000S recently with a airfuel ratio in need of some enrichment and it came in at just under the 145 mark to the wheels (which wasn't bad considering). I'm waiting on a chip to regain some ponies lost to a midpipe swap made earlier. My hope is it will give me back the 5 or 6 horepower lost by the pipe swap, plus maybe a little extra once I change out the air filter and it's able to breath freely.
M
Guest
I just had my F4R dyno'd for a custom PCIII map
2007 MV F4 1000R
-MV Titanium slip-ons
-MV Midpipe (no cat)
-BMC race air filter
-Stock ECU
Max power = 156.19
Max torque = 74.35
Elevation = 5280'
I will keep my F4R out from any Dyno test. I don´t want to know the real truth.
I will fit a Ti F1 slip-on and mid pipe no cat MV Agusta Corse with a BMC air filter, and the new MV ECU for the Ti F1 as well.
Just I hope this will increase the Power and reduce the weigth, but I will leave it for my imagination.
As said in The Matrix, "ignorance is happiness". :f4:
Err why does it even matter whether you know how much hp your bike is making or not? For me the answer is it is a good way to find out if there is a mechanical fault on my machine if the numbers are off by say 15 hp. Once you know a ball park figure, and you compare with others and if you are around the same figure then you know your machine is fine. Its sort of a yardstick for me. I will be fitting a Motocorse Ti full setup, PC3 and air filter and have a custom map made. I am all for losing weight. That bike is heavy!
1 - 14 of 14 Posts
