1 - 3 of 3 Posts
Should have posted in this forum first:
A couple questions here:
1) I am way overdue for the 6000 km service. I thought I would do the oil myself, because it will be anther 500 km before I get to the dealer. Do I really need any special tool? Or will my standard filter wrench (I use for the Suzuki) work just fine? To forestall the obvious question: no I don't have a filter on hand to check with!
2) Are there any special tools required for the throttle bodies and drive chain? The manual says there are but.... Maybe not?
I would just add that when you re-tighten the swing arm eccentric after adjusting the chain use an accurate torque wrench as you can strip the threads on the fixing bolts easily if you over do it. :)
1 - 3 of 3 Posts
