1 - 9 of 9 Posts
can someone please tell me standard preload on rear shock,and are the suspension settings in the rear of manual all taken from fully wound out thanks
What are the track day settings for the rear shock?
In the manuals, track day settings are the same as for the road? The forks have a different setting so I wonder if it was just a typo on the shock?
Check the pockets of the manual in the rear. There is a folded piece of paper that has all the specs on it for only the suspension.
The manuals, owners or workshop, is pretty much just a guide, you weight is the deciding factor.
yes i know,going to set standard then see where me sag readings were,think it will be way over sprung as im only 75kg
1 - 9 of 9 Posts
