bike has ABS unfortunately, just swapped the rcs19 on and didn't disconnect any lines anywhere except the master downline. Im thinking if up pressure bleed from front calipers I can push the air (now at the banjo bolt for new master) up and out very easily. I will just use a ton of fluid since im replacing it with rbf600. Already bleed the rear using traditional press lever turn nipple approach successful.
or Do I have to take the whole damn thing apart again? not like it runs at all anyways
on another note, the oem res is in a peculiar position and I cannot figure out how to run the hose... I have tried super short, medium, and crazy long hose arrangements.... if the res tip was pointed parallel with the bike instead of perpendicular it would be a breeze.
