1 - 10 of 10 Posts
Hi guys,
My factory stock grips have slight fades in them and have gotten weaker. I’d like to replace them with something aftermarket. Anyone know the specs of the grips or have any options out there that you guys have switched to?
Thanks in advance
Wing Nut
Grips are grips... I use progrip superbike gel grips.
Wing Nut
They are a standard open end grip...same as used on almost every sport bike made.
Hi guys,
Thanks in advance
Bars are 22mm or 7/8
BMW HP4 Carbon 2013, ZX10R Gen 1 2004, F3 800 2017
Anyone fitted heated grips to theirs, I've heated grips on my HP4 and they're brilliant.. was looking at some options.
2017 F3 800, HP4 Comp, ZX10R
Are these able to fit on the throttle side? Maybe with a different cam adapter?
There needs to be more information here: Your year and model of bike? (Yes I see F3 in the title....but no longer down here in the meat of the thread.) The component manufacturer and part number? The seller you dealt with?
Additionally, placing the same question in more than one thread only adds to the confusion.
I am going to delete your other thread on the same subject.
I fitted Oxfords to my MV - all works perfectly
1 - 10 of 10 Posts
