One of the 2 posts on the starter solenoid has a little strap that goes over to the 4-pin connector. That is the post for the battery.
They are labeled..."B" is battery..."M" is starter motor.
Oh, you meant which lead is which..... use a volt meter or test light and see which one is "hot".
...and those should be 40 amp fuses....
