I stumbled upon a pair of used F3 675 '15 front brake disks, 4.9mm thickness.
Would these disks fit the butale 800 '13? As far as I know the fronts of these bike are pretty much the same.
From the pictures it looks like the F3 disks (gold hub) are axially offset by a bit, but maybe that's optical ilusion. The brutale disks (black hub) are completely flat.
Any input is greatly appreciated! Thanks!
I would say no they will not fit. That is due to the offset you see.
Use this diagram to compare:
I don't think the disks with the gold hub are from a F3; never seen gold hubs on an F3
If I use the partlist I see the F3 675 and 800 aswell as the B3 use the same discs.
I recently changed my stock discs (F3 800 2013) for Braking Wave discs so if you are in need for standard discs sent me a message.
