So after ceramic coating my entire exhaust i replaced the OEM packing in the tips with some Yamaha OEM stuff. It seems to have started to melt after a spirited ride and left some residue in the tip caps :( I'm guessing this is due to the higher exhaust gas temps. Any tips on stuff that can withstand a higher temp? The Yammie stuff looked like E glass. So anything like that probably won't help.
Message Noel "theknurl" he used to make exhaust systems and may be able to give you the Right advice.
I use FMF packing, wrap it tight, then a couple of layers of aluminum foil, bind with
safety wire and insert into the muffler .....now pull the safety wire
works as well as anything I know of
looser the pack, faster the exhaust pulses will beat it apart
:popcorn:
