1 - 9 of 9 Posts
I fitted one to my Panigale 899, wasn't too bad, instructions were comprehensive and easy to understand.
Reactions: Duketwo
I'm very happy with the EvoTech tail tidy on my Street Triple.
Regarding the MV part linked, is it possible to separate the part that mounts the indicators? I might be going with the integrated tail light, so the indicator mounts would be redundant (not not very 'tidy' if unused).
The red box is around the plate that needs to be bolted onto the main holder.
As you can see from the 2 side holes in the plate, that is the position where the blinkers go.
The middle big hole is for the lincense plate light.
U can mount it without the blinkers, but not sure if it looks good or clean.
Thanks @Black_Gold_Saw, to clarify, could you choose leave off that part that's in the red box?
I have the Evotech tail tidy on my 2013 Diavel.
Well made, strong, looks good.
Much nicer than the funny looking stock number plate mount.
Cops don't seem to have an issue with it.
Reactions: Duketwo
I believe u can. Its purpose is to mount the license plate light and blinkers.
The 2 diagonal holes on the main tail tidy are for mounting the license plate.
EDIT: I made a photo of the holder. The yellow lines is the bracket for license plate light and blinkers. As you can see it mounted with 2 bolts.
The blue lines are the main tail tidy.
Hope this helped you out.
1 - 9 of 9 Posts
