Managed to make a high-sider with the bike during the weekend's races. Smashed the hand control on the left side, and now i get an error message on the display. How do I reset to error codes on a F3? The bike starts and run fine but the engine map is in normal and i cant change it.
I cannot be done by a home tech. It requires a hookup to a diagnostic such as a Texa system.
Unfortunately, yes. It should take them all of 5 minutes to reset and clear error codes. Make sure they tell you of any other errors that have been stored but not displayed.
See cord to the instrument panel coming san bus
You can see what she is still in the circuit of the electrical
сan bus goes from the ecu to the instrument panel, Lean angle sensor, and a diagnostic connector. please make sure that these plugs are intact.
the error will go away as soon eliminate it
It proved to be the dash which is broken so now I need a new one.
Anyone have one?
Is there a Race Dash that is plug and play with the MV F3?
