1 - 13 of 13 Posts
Can anyone help with EPROM installation? I just finished installing midpipe and need to change out the EPROM.
B Smith
Senna 243
Thank you, I had seen this EPROM replacement described already. I do not have this rubber plug on my computer as shown in the link. I'm assuming the computer is located the same as it is on my 916 under the tail section.
If the bike is like my brutale 910 take the tank off. Then the ECU is right in front of you. Take it off the bike turn it over. Take off the sticker theres the rubber plug.
On my Brutale 750 the ECU sits on top of the airbox, under the tank.
Maybe the location depends on how many espresso's the MV factory guys have had the day they build your bike :ahhh:
OZBOY...SSSHHHH My wife might here you. Lets see last count 8, but I am in clear out mode, down to 4.
By the way, my Brutale was one of the first I had it air freighted direct from the factory before they were even released out here, so maybe it had some bits that have been modified in later versions?
1 - 13 of 13 Posts
