1 - 3 of 3 Posts
Coolant Temperature
I wanted to ask a basic question about coolant temp. I have noticed my F4 1000 seems to run pretty hot. When I am cruising around north of 50 mph, it's usually around 170-190, but when I stop, almost immediately the temp rises north of 210-220 and the fan kicks on. The other night, I was with a group of riders, and a friend of mine had his R6 idling for several minutes. I noticed his temp was running 175. If my MV sits and idles, it would be in 200+ country.
I assume this is normal for the MV, but wanted to check with you all.
Especially normal for AZ, even in the winter. Onlt difference is, when the outside temp is below 70, the fan can actually cool the bike, during the summer I regularly kill the engine at long stops.
1 - 3 of 3 Posts
