hi, i'm trying to find the engine number on my MV F41000 (2006). i've looked behind the shock but no luck. can anyone advise where else to look?
thanks.
Steve
I have a 2007 1000R Senna and the engine number is behind the rear shock on the back of the engine case. It is somewhat hidden by the rear brake fluid reservoir. If you can find the reservoir, look behind it and you will see an "F5" number stamped on the case.... that is it.
Its located on the fuel pump, inside the tank. :naughty:
no, just kidding, it should be on the engine.
It's probably pretty dirty, but it's there on the rear face of the engine case. There's a row of stamped letters, then it says "MV AGUST F5", with the serial number below that.
