Enduro Veloce Clutch switch failure
1 reading
118 views 1 reply 2 participants last post by  esq'z me
#1 ·
Hi, on the weekend ride I noticed my MV idle didn't drop when I pulled up to a set of light with the clutch held in.
It usually drops by a couple of hundred RPM.
Anyway later after thinking about it and wondering if it was the clutch switch I did the try and start it in first gear, clutch in,side stand up..
It wouldn't start unless in neutral..
The switch appears to be a small metal headed plunger type rather than an actual micro switch.
It will be going to be checked under warrenty but I wondered if there's any tricks ,cleaning ,adjustments or maybe it just a failure.
Any advice appreciated.
#2 ·
It is an on/off switch.
I would guess jumping the connector to make it always on would work, but might do things to your mapping as the ECU will think the clutch is always disengaged ….
Reactions: Paul.B
