1 - 9 of 9 Posts
Hi, I have replaced the pathetic sounding original horn with a much louder electromagnetic one as used in cars.
Unfortunately I can’t find any space for the new larger horn other that at the top of the front radiator. There is a danger of the front mudguard hitting it should i go over a pothole or bump when the front shocks get very
compressed.
Has anyone else replaced theirs in a better location? Many thanks.
I have never thought about replacing the horn. As a safety feature, it would be a good idea. The light bar is a safety feature for mine where you put the horn. It required grinding the light bracket so the fork gap would not compromise the forks.
Reactions: sarje88
Stebel makes a horn that is air driven and waterproof and is very loud. I have the chrome version on my Monster S4Rs. Amazing piece of gear.
I bought a waterproof horn and relocated it here. It is just a tad too big such that the side grey panel touches the horn. I placed some tape over the contact area and removed the grommet for the push-in plug at the bottom of the panel for more room. I then pushed in a rubber washer to hold the plug in place.
This is the grommet I had to remove. I guess the trick is to buy a smaller horn but I think they are all about the same size.
1 - 9 of 9 Posts
