1 - 10 of 10 Posts
So, I am back to a stock ECU after Rob's attempt at a re-flash. This time around I'm going to do some more research and looking around before I make my next decision on how or who tunes my Senna before I grab the Franklins out of my wallet and wave them around.
Rob says that a full Dyno tune would run me $800. That's also after I have already spent $250 for the flash and the $$ for back and forth shipping a few times.
I have also been talking to Dave at Rexxer and he offers a dyno tune on the bike as well, would cost me no more than $600. He is also a bit closer to me (VA vs. MA to go see Rob)
I'm in FL so trying to stay as close as I can and get the most bang for my traveling buck as it seems as I will have to travel somewhere to get a Dyno tune.
Does anyone have any other recommendations or someone I should talk to and compare with? I'm looking for a strictly on the dyno tune. Not going to mess with a flash or out of the box mapped ECU.
Any suggestions would be appreciated, thanks.:yo:
Curtis, did the reflash back to stock cure the high idle issue?
Discussion Starter · #3 ·
Yes it did. Unfortunately the lower turn on temp for the fans went with it as well. Not that they had anything to do with one another, just stating that I didn't get to retain that either.
Bummer...sorry about the lack of Dyno Time for you.
It's amazing the small differences in engine internals can make.
Discussion Starter · #5 ·
No worries. You live and you learn, and Lord knows I have got a lot to learn. Your help was over the top regardless. So thank you.
Formerly - dagmvagusta
I live in NC and have 2 great dyno shops I have been to here. I have a 2012 F4R 1000 with 190rwh. Look up max speed performance and adams performance. Adams builds and maintains the engine for Ricky Gadson motorsports.
Discussion Starter · #8 ·
I will definitely look them up. Thanks!! And did they tune your stock ECU, or are you using a Power Commander or Microtec?
Thanks Blackout! I've been looking for a nearby dyno shop as well. In your experience, is one any better than the other?
I have a Bazzaz fi qos fuel management system. With the Bazzaz you can have 2 customary built so that's why I had 2 done. I liked them both as I have known Jim at max speeds since 2007. However, I love adams performance as I know he got every once of power out of it.
1 - 10 of 10 Posts
