Actually, I have a PC usb, not an eprom. I purchased the PC from a local shop and the mid pip from Pirates Liar www.piratesk12site.net. The dyno was performed at Ferracci'schromeframe said:I have been impressed by your dyno chart. I have added the BMC filter from Ferracci but have been rekuctant to replace the cat and install a new eprom. Where did you purchase the midpipe and eprom ?? Was it a simple replace and go ?? Thanks...........KO...ps who did you go to for the dyno run ??
Yo redrocket, it's MilleR :king:reptile said:Is that measured at the wheel?? :wtf:
Hey MilleR how're you doin? It's really great to see you here. I've eventually succumbed and put down a deposit on a MVF41000S1+1 It took a big crash for me to make the decision though. I pick the bike up first week in June. I've got a broken ankle and hand still and the pins don't come out of my hand till mid May so I figure I should riding again by June.MV-999R said:Yo redrocket, it's MilleR :king:
Wouldn't the higher temps cause lower numbers versus running in a cooler room?airfuel said:Almost 108 degrees F in Feraccis dyno room??![]()
Something is wrong here....maybe his stack (weather station that corrects for conditions) needs to be fixed. This also may be why his dyno produces much higher numbers than any other in the industry!
yes, it would. higher temps mean lower air density -> lower power.Shogunz said:Wouldn't the higher temps cause lower numbers versus running in a cooler room?
Display Negative—When Display Negative is toggled on, all data is displayed. When off, the data is cut off below zero and only positive data will be displayed.
Display—determines what will be displayed on the graph. When printing the graph, note that the Conditions will always be printed.
Correction Factor—lets you select the correction factor applied to the data.
Smoothing—lets you select the level of smoothing to be applied to the data.
Hard to say seeing as none of us were there. But given that the previous run was done just an hour earlier it could have heated up during the first run. Besides I don't see what advantage Ferracci would have for doing the second run in warmer temps. You would think they would try to do the mod run in cooler temps right?airfuel said:Do you think it really was 108 degrees in there?(I don't)
Big temps screw with the SAE numbers.
Hey, WOW!!!!!!!!!!!!!!!!!.......... i didn't knew you had crashedreptile said:Hey MilleR how're you doin? It's really great to see you here. I've eventually succumbed and put down a deposit on a MVF41000S1+1 It took a big crash for me to make the decision though. I pick the bike up first week in June. I've got a broken ankle and hand still and the pins don't come out of my hand till mid May so I figure I should riding again by June.![]()
Yep I sure did, there's post all about it on the R1 forumMV-999R said:Hey, WOW!!!!!!!!!!!!!!!!!.......... i didn't knew you had crashed![]()
What happend? Did you crash on the road or on the track?
I'm truly sorry to hear thatHeal up quickly and i hope you'll be ready for you MV in June :smoking:
Ah........ and it's great to see you here too![]()
