1 - 2 of 2 Posts
Ade;
the MV TBs are garbage and built backwards too....the 'uphill' side of the blades is larger......
causing them to want too stick
so to kill vacuum they retarded the motors to -4deg (1000S) and then -10deg (1000R)
which makes them over heat
with the TBs on my Aprilia RSVR if you hold them inverted and put a tablespoon of paint thinner on the blades.....2 minutes later almost all of it is still there
real TBs :drummer:
for syncing I use a UniSyn
http://www.jegs.com/images/photos/3504025.jpg
you need to plug the stupid holes in the air horns so the tool will work
1 - 2 of 2 Posts
