does the Dragster, Rivale, Brutale and F3 share the same oil drain plug washer (same oem part number).
Amish;
just reuse the old one.......I have 526,000km on an original drain plug gasket
:drummer:
:popcorn:
the F4 and B4 use a M22 x 1.5 drain plug
the washer is ~2 X 22.2 x 28
part # 62n015682
the 3 cylinders are probably the same measure the plug
the issue is… i have misplaced the original washer and don't know where it is.
How could you misplace the washer?Like Noel said just measure the diameter of the drain plug and go to your nearest auto store and buy a packet of alloy washers,easy.
Discussion Starter · #6 ·
thanks guys. my dealer is mailing me new drain plug and washers. Waiting for them to arrive.
Once i did my first oil change, i replaced the washer and put the old (original) washer in a box. and now i can't find it.
Mitch;
why do I bother????????
Amish......
your 1st washer didn't leak why did you replace it???????
Discussion Starter · #8 ·
i had changed it because it mentioned on the manual.
Got new oem washers from the dealer. Slapped one of hem on and no problem.
