1 - 20 of 20 Posts
Hi team,
I started gaining oil drips after 1 1/2 years of happy Dragster RR ownership - noticed at the third sprag clutch warranty fit. We monitored the oil drip and thought the oil bung, changed the oil bung, and still have the drip. The only MV authorized service centre 450kms away, the other side of New Zealand, checked it out, and found it to be a crack in the crankcase.
To add to this headache, the 3rd Sprag Clutch with software update has seen failed starts starting to occur in the last two weeks. From experience in sprag fails, I predict incoming...
I love this bike and still goes like it did on day one. Still in mint condition, looked after, and never been over.
Oil changes have seen nothing strange or extra foreign bits. Its full noise and not complaining or making any noises. There's definitely nothing foreign in the engine that the service centre wants to take my bike in for to check, even if there was, it would be through other MV warranty work. This seems crazy when they have the test result and took photos? I do realise they need to find out what other parts are needed if internal cause. My scare is not seeing the bike again for months and an advanced bill.
What process would I expect to follow on fixing the crankcase under warranty with MV Agusta? How does this work around the world for MV Agusta?
Any experienced crankcase experts hazard a guess on what could cause a crack in the crankcase shown in the image? Stress or possible internal foreign body?
Thanks for reading. Captain Jon of Port Motueka, New Zealand. ⚓
I'd probably weld it up, too.
It looks like it cracked at a stress riser where the swingarm, frame and engine come together. If there were a missing spacer in there, it could cause stress and eventually a crack I suppose.
If MV is taking it on, get a limit of liability on the repair if they aren't going to simply warrant the repair.
BTW, welcome! My wife and I have good friends in Palmerston North...we love NZ!
Nice job on the dye penetrate test....right at the motor mount.!!!
Loose motor mount bolt? improper spacing at assembly? Porous casting?
MV, like any other manufacturer, will only pay for warranty repairs performed by an authorized dealer....so if it is under warranty you will have to take it there.
How many miles on your bike? I would expect MV to be curious about this as it is a very unusual failure.
Thanks everyone for your feedback on this dilemma.
Very good point here: Would I ask the MV service centre, their NZ/AU distributor they answer to, or MV Agusta Italy, in regard to limit of liability of the repair?
I've done 30,000kms in two years. Its been great apart from Sprag Clutches. (Last one took five months to gain.)
Issue is the only MV authorised dealer is other side of New Zealand. Without being near it, my bike would live in there for months at their mercy.
Crack?
Fishcookie;
I can weld just about anything.......
That said I'd groove the crack out a ways and clean it off with lacquer thinner
And repair it with epoxy, make SURE IT'S CLEAN 1st
:wink2:
Fishcookie;
:wink2:
JB Weld is your friend !!!!
Reactions: Teeps
I would be tempted to use something with some flex to it.
Some motion or stress caused that initial crack.
Actually, vibration will continue the crack propagation.
I'd end-drill the crack, then seal the crack.
Cleaning?
Fishcookie;
Do you have access to an air compressor?
If so, take a 6-8" length of rubber hose and slip it over the end of the air
blaster and clamp it...... pinch the end so it fits the crack and blast away
Don't forget to remove the oil fill plug 1st
:wink2:
Discussion Starter #13 (Edited)
So, I decided to take the bike on a run to work and back today, and this saw its 3rd Starter Motor with new map heading to end of life quicker than I expected.
I managed to video it failing, seeing and hearing there's 100% power delivery in the uprated battery to save the Starter Motor, two attempts, but no start... If I had the original battery in I would have been stranded. The third attempt and she's on... Phew.
Two really good oil drips left the crankcase for the tarmac at work. It sure gets messy back there real quick.
On the up side, our lovely friends in Varese are saying they are going to help the Captain out, its great to see good communication direct from the manufacturer.
Let's see how it all pans out here on the other side of the world. Thanks for all your responses to my Dilema. :)
Which MV Agusta has a reliable Sprag Clutch similar to a Dragster RR? I can't do this 900kms round trip every nine months anymore...
Part of the Sprag Issue is the ECu programming for the engine start. If you get the updated Sprag, which all of them should be by now, you also need the latest ECU mapping installed form your dealer.
Let's see how it all pans out here on the other side of the world. Thanks for all your responses to my Dilema. <img src="http://www.mvagusta.net/forum/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
How and the hell do you get good communication direct from the manufacturer? I finally got ahold of someone that gave me the same generic answers and push offs to other parts of company. “An email should be sent sometime this week.” So sick of this company and it’s not taking care of its customers. Seen it over and over on these forums. Time to invest in another company that actually takes care of its customers after they’ve got your money from initial purchase. Very sad to see
Discussion Starter #17
The time difference is tricky. I've contacted MV Agusta four times this week with responses by the next morning. I would say that is good communication.
It might have to do with attitude.
@Fishcookie, where are you on this planet?
@Fishcookie, I will give you that you are certainly on a Different Planet!
My wife and I, along with @esq'z me (Ed) and his now wife Pam, had the lovely opportunity to explore your planet for three weeks with a friend from Palmerston North. @The_castle (Dave and Melanie).
Beautiful country, really. Nice people...extraordinary actually. It is the first place I have been outside of the USA where I felt like I could have stayed and been very happy.
I am looking forward to the return visit.
Chuck
1 - 20 of 20 Posts
