1 - 9 of 9 Posts
Does anyone know what the "Starter Safety Central Unit" is on the F4?
I'm troubleshooting the bike and the service manual says that this can be defective but when I search for this in the .pdf file it only comes up the one time when it says that it's defective.
I thought maybe it would be the starter motor but the manual makes it pretty clear when it refers to the 'starter motor' or 'starter relay'.
Any thoughts?
Hi turbo,
I think it is just inconsistent translation from Italian to English.
I've checked the manual, and for the various models and years they are talking about;
Starter safety central unit faulty. See page 28.
Engine control unit broken. See page 28.
Check the starter relay. See page 28.
When you go to this page 28 it shows a picture of the starter relay.
I hope this helps,
Willy
Thanks bud. I've actually checked the starter relay and it's good. It had voltage.
CAG sent me a new starter motor and hopefully that resolves the problem but I was wondering if there was anything else that it could be.
Could it be an interlock relay that prevents starting in gear with side stand down or clutch not pulled whilst in gear? I haven't studied the schematic for this yet, but that is an item most Jap bikes have.
Are you sure the starter motor is faulty?
You could easily check it by bridging the whole starter circuit, to do this you take a piece of wire and hold it on the battery "plus" pole, and the other end on the starter motor wire directly on the "plus" pole of the starter motor.
If you can, use a battery jumper cable, if the wire diameter is too small it will get so hot that it will for sure burn your fingers, if you only have a small diameter wire just don't run the starter motor too long, then you should be alright as well.
checking the starter;
key off, short across the 2 large solenoid terminals, the starter should crank...assuming the battery is good and the terminals are tight....
checking the solenoid;
if that made it turn over, put a jumper from the battery+ terminal on the solenoid to the small terminal on the solenoid.....if it cranks....its some thing in the interlock system
like Ed said, i haven't looked at it either
Noel-theknurl
Hey Noel, we try to short the relay and it didn't crank. Does that mean it's the starter motor?
Thanks to CAG I just received a replacement motor yesterday but just wanted to get you guys input before I pull the bike apart.
...My bike is 5 years old but it only has 3,000 miles. That's weird that the starter motor would go. I'm wondering what I did wrong to make it die so early in it's life.
its probably the starter, so run a large jumper from the battery to the starter.....
you already got another from CAG but....
Denso starters all have the same drive gear and armature....the end plates are different at the mounting lugs
if it needs brushes you can buy new brushes through PartsUnlimited or Rick's. it has 2 brushes
when you pull the armature out of the brushes ....you will need to retract them with 2 pieces of sheet metal bent 90deg held in place with needle nose Vise Grips
Noel-theknurl
Okay. I just have 1 more stupid question.
If I run a jumper cable from the battery to the starter and it starts up, does that mean that it's a wiring issue and not the starter?
If it doesn't start up then it's likely the starter motor, correct?
I'm wondering if when I had the tank off that I jacked up the neutral cable and if that could have some effect too.
Noel-theknurl
1 - 9 of 9 Posts
